Run Time: 0.001877
Run Time: 0.000265
Run Time: 0.000304
WHERE (`xf_thread`.`thread_id` = '681')
Run Time: 0.000853
WHERE (`xf_post`.`thread_id` = 681) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001943
Run Time: 0.000399
Run Time: 0.000372
Params: 681
Run Time: 0.000123
Run Time: 0.000841
Run Time: 0.000407
Run Time: 0.003036
Run Time: 0.000757
WHERE (`xf_thread`.`title` LIKE '%Karbonhidratlar%') AND (`xf_thread`.`title` LIKE '%ve%') AND (`xf_thread`.`title` LIKE '%Proteinler%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 681) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.014153
WHERE (`xf_thread`.`title` LIKE '%Karbonhidratlar%') AND (`xf_thread`.`title` LIKE '%ve%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 681) AND (1) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.013625
WHERE (`xf_thread`.`title` LIKE '%Karbonhidratlar%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 681) AND (1) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.011100
WHERE (`xf_thread`.`title` LIKE '%ve%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 681) AND (1) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.005060
WHERE ((`xf_thread`.`thread_id` = 1375) OR (`xf_thread`.`thread_id` = 1362) OR (`xf_thread`.`thread_id` = 1359) OR (`xf_thread`.`thread_id` = 1358))
Run Time: 0.000430
Params: 0, , , XF\Pub\Controller\Thread, Index, valid, thread_id=681, 1714787120,
Run Time: 0.000187
Run Time: 0.000994
Run Time: 0.002025
Run Time: 0.000366
Run Time: 0.000327
Run Time: 0.000562
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712195120)
Run Time: 0.001799
Run Time: 0.001290
Run Time: 0.000352
Run Time: 0.000302
Run Time: 0.003111
bytes_sent | 50887 |
bytes_received | 946527 |
packets_received | 3783 |
protocol_overhead_in | 15132 |
bytes_received_prepare_response_packet | 250820 |
bytes_received_change_user_packet | 693167 |
packets_received_prepare_response | 3088 |
packets_received_change_user | 471 |
rows_skipped_ps | 419 |
proto_binary_fetched_bit | 2845 |
proto_binary_fetched_short | 2182 |
proto_binary_fetched_int24 | 777 |
proto_binary_fetched_bigint | 7549 |
proto_binary_fetched_float | 118 |
proto_binary_fetched_json | 4118 |
proto_binary_fetched_blob | 1672 |
bytes_received_real_data_ps | 681738 |
