Run Time: 0.001736
Run Time: 0.000485
Run Time: 0.000272
WHERE (`xf_thread`.`thread_id` = '239')
Run Time: 0.001007
WHERE (`xf_post`.`thread_id` = 239) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001344
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 5 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (1147))
Run Time: 0.000541
Run Time: 0.000434
Run Time: 0.000408
Params: 239
Run Time: 0.000150
Run Time: 0.001174
Run Time: 0.000325
Run Time: 0.002629
Run Time: 0.000761
WHERE (`xf_thread`.`title` LIKE '%2022%') AND (`xf_thread`.`title` LIKE '%Mühendis%') AND (`xf_thread`.`title` LIKE '%Taban%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 239) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.006988
WHERE ((`xf_thread`.`thread_id` = 313) OR (`xf_thread`.`thread_id` = 312) OR (`xf_thread`.`thread_id` = 311) OR (`xf_thread`.`thread_id` = 310))
Run Time: 0.000359
Params: 0, , , XF\Pub\Controller\Thread, Index, valid, thread_id=239, 1714834265,
Run Time: 0.000193
Run Time: 0.000920
Run Time: 0.001701
Run Time: 0.000289
Run Time: 0.000382
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712242265)
Run Time: 0.002227
Run Time: 0.001614
Run Time: 0.000525
Run Time: 0.000319
Run Time: 0.002361
bytes_sent | 31263 |
bytes_received | 952515 |
packets_sent | 292 |
packets_received | 3565 |
protocol_overhead_in | 14260 |
protocol_overhead_out | 1168 |
bytes_received_rset_header_packet | 882 |
bytes_received_rset_row_packet | 274 |
bytes_received_prepare_response_packet | 239394 |
bytes_received_change_user_packet | 710863 |
packets_sent_command | 145 |
packets_received_rset_header | 98 |
packets_received_rset_row | 50 |
packets_received_prepare_response | 2900 |
result_set_queries | 46 |
ps_buffered_sets | 46 |
ps_prepared_once_executed | 47 |
rows_skipped_ps | 421 |
proto_binary_fetched_bit | 2894 |
proto_binary_fetched_short | 2255 |
proto_binary_fetched_int24 | 805 |
proto_binary_fetched_bigint | 7774 |
proto_binary_fetched_decimal | 106 |
proto_binary_fetched_float | 122 |
proto_binary_fetched_json | 4197 |
proto_binary_fetched_blob | 1747 |
com_stmt_prepare | 48 |
com_stmt_execute | 48 |
com_stmt_close | 47 |
bytes_received_real_data_ps | 699216 |
