Run Time: 0.001329
Run Time: 0.000257
Run Time: 0.000895
Run Time: 0.000360
Run Time: 0.002876
Run Time: 0.000922
Params: 0, P-, P-, XF\Pub\Controller\Forum, List, valid, , 1715022179,
Run Time: 0.000143
Run Time: 0.001205
Params: 1715021279
Run Time: 0.000457
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 138 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715021279)
Run Time: 0.000573
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 138 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712430179)
Run Time: 0.001240
Run Time: 0.001365
Run Time: 0.001018
Run Time: 0.000253
Run Time: 0.000246
Run Time: 0.000355
Run Time: 0.001532
Run Time: 0.002311
