Run Time: 0.001175
Run Time: 0.000189
Run Time: 0.000722
Run Time: 0.000319
Run Time: 0.002473
Run Time: 0.000551
Params: 0, ِ , ِ , XF\Pub\Controller\Forum, List, valid, , 1714922355,
Run Time: 0.000155
Run Time: 0.000670
Params: 1714921455
Run Time: 0.000386
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 136 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714921455)
Run Time: 0.000572
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 136 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712330355)
Run Time: 0.001445
Run Time: 0.000984
Run Time: 0.000756
Run Time: 0.000151
Run Time: 0.000247
Run Time: 0.001493
Run Time: 0.000153
Run Time: 0.001941
