Run Time: 0.001248
Run Time: 0.000229
Run Time: 0.000762
Run Time: 0.000359
Run Time: 0.002313
Run Time: 0.000551
Params: 0, 4pE, 4pE, XF\Pub\Controller\Forum, List, valid, , 1714454428,
Run Time: 0.000127
Run Time: 0.000758
Params: 1714453528
Run Time: 0.000352
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 18 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714453528)
Run Time: 0.000580
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 18 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711862428)
Run Time: 0.001771
Run Time: 0.002128
Run Time: 0.001257
Run Time: 0.000314
Run Time: 0.000339
Run Time: 0.000305
Run Time: 0.000277
Run Time: 0.000382
Run Time: 0.001456
Run Time: 0.002190
bytes_received | 941537 |
bytes_received_change_user_packet | 714420 |
bytes_received_real_data_ps | 702403 |
