Run Time: 0.001791
Run Time: 0.000290
Run Time: 0.000266
Run Time: 0.000793
Run Time: 0.000343
Run Time: 0.002907
Run Time: 0.000567
Params: 0, i, i, XF\Pub\Controller\Forum, List, valid, , 1714484753,
Run Time: 0.000133
Run Time: 0.000887
Params: 1714483853
Run Time: 0.000329
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 33 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714483853)
Run Time: 0.000699
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 33 | Using where |
Run Time: 0.000239
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711892753)
Run Time: 0.001473
Run Time: 0.001058
Run Time: 0.000992
Run Time: 0.000280
Run Time: 0.000310
Run Time: 0.000392
Run Time: 0.001667
Run Time: 0.002241
bytes_sent | 23314 |
bytes_received | 939650 |
packets_sent | 286 |
packets_received | 3429 |
protocol_overhead_in | 13716 |
bytes_received_change_user_packet | 714945 |
packets_sent_command | 142 |
packets_received_change_user | 467 |
result_set_queries | 46 |
ps_buffered_sets | 46 |
proto_binary_fetched_bit | 2911 |
proto_binary_fetched_json | 4420 |
proto_binary_fetched_blob | 1743 |
com_stmt_prepare | 47 |
com_stmt_execute | 47 |
com_stmt_close | 46 |
bytes_received_real_data_ps | 702921 |
