Run Time: 0.001185
Run Time: 0.000369
Run Time: 0.000266
Run Time: 0.000902
Run Time: 0.000316
Run Time: 0.002356
Run Time: 0.000611
Params: 0, , , XF\Pub\Controller\Forum, List, valid, , 1716372837,
Run Time: 0.000157
Run Time: 0.001039
Params: 1716371937
Run Time: 0.000368
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 19 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1716371937)
Run Time: 0.000624
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 19 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1713780837)
Run Time: 0.001578
SIMPLE | xf_thread | range | last_post_date | last_post_date | 4 | | 41 | Using where |
Run Time: 0.001184
Run Time: 0.001159
Run Time: 0.000384
Run Time: 0.000267
Run Time: 0.000500
Run Time: 0.000403
Run Time: 0.000252
Run Time: 0.000242
Run Time: 0.000398
Run Time: 0.004064
WHERE (`xf_session_activity`.`user_id` = 994) AND (`xf_session_activity`.`unique_key` = '994')
Run Time: 0.000249
Run Time: 0.000242
Params: 24
Run Time: 0.000368
- XF\Template\Templater->func() in internal_data/code_cache/templates/l2/s6/public/xgt_FrmIstatistik_yeniMesajlar.php at line 184
WHERE (`xf_session_activity`.`user_id` = 852) AND (`xf_session_activity`.`unique_key` = '852')
Run Time: 0.003009
bytes_sent | 25566 |
bytes_received | 1021201 |
packets_sent | 346 |
packets_received | 3688 |
protocol_overhead_in | 14752 |
protocol_overhead_out | 1384 |
bytes_received_rset_header_packet | 1143 |
bytes_received_rset_row_packet | 313 |
bytes_received_prepare_response_packet | 232613 |
bytes_received_change_user_packet | 785836 |
packets_sent_command | 172 |
packets_received_rset_header | 127 |
packets_received_rset_row | 59 |
packets_received_prepare_response | 2935 |
packets_received_change_user | 508 |
result_set_queries | 56 |
ps_buffered_sets | 56 |
ps_prepared_once_executed | 56 |
rows_fetched_from_server_ps | 452 |
rows_buffered_from_client_ps | 452 |
rows_skipped_ps | 452 |
proto_binary_fetched_bit | 3256 |
proto_binary_fetched_bigint | 10629 |
proto_binary_fetched_decimal | 106 |
proto_binary_fetched_json | 5433 |
proto_binary_fetched_blob | 2048 |
com_stmt_prepare | 57 |
com_stmt_execute | 57 |
com_stmt_close | 56 |
bytes_received_real_data_ps | 771542 |
