Run Time: 0.001229
Run Time: 0.000260
Run Time: 0.000692
Run Time: 0.000310
Run Time: 0.002411
Run Time: 0.000542
Params: 0, wvc, wvc, XF\Pub\Controller\Forum, List, valid, , 1714999090,
Run Time: 0.000185
Run Time: 0.001319
Params: 1714998190
Run Time: 0.000492
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 176 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714998190)
Run Time: 0.000674
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 176 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712407090)
Run Time: 0.001576
Run Time: 0.001181
Run Time: 0.001425
Run Time: 0.000281
Run Time: 0.000266
Run Time: 0.000245
Run Time: 0.000372
Run Time: 0.000398
Run Time: 0.003059
Run Time: 0.000490
Run Time: 0.000282
Run Time: 0.001890
bytes_received | 946885 |
bytes_received_change_user_packet | 719768 |
proto_binary_fetched_bit | 2948 |
proto_binary_fetched_json | 4500 |
bytes_received_real_data_ps | 707563 |
