Run Time: 0.001280
Run Time: 0.000723
Run Time: 0.000288
Run Time: 0.002411
Run Time: 0.000554
Params: 0, tUH, tUH, XF\Pub\Controller\Forum, List, valid, , 1714313741,
Run Time: 0.000125
Run Time: 0.000603
Params: 1714312841
Run Time: 0.000324
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 82 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714312841)
Run Time: 0.000588
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 82 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711721741)
Run Time: 0.001305
Run Time: 0.001298
Run Time: 0.000855
Run Time: 0.000251
Run Time: 0.000226
Run Time: 0.000313
Run Time: 0.001376
Run Time: 0.002119
bytes_received | 942172 |
bytes_received_change_user_packet | 715055 |
proto_binary_fetched_bit | 2913 |
proto_binary_fetched_short | 2379 |
proto_binary_fetched_int24 | 912 |
proto_binary_fetched_bigint | 8349 |
proto_binary_fetched_float | 145 |
proto_binary_fetched_json | 4439 |
bytes_received_real_data_ps | 702974 |
