Run Time: 0.001427
Run Time: 0.000395
Run Time: 0.000248
Run Time: 0.001076
Run Time: 0.000530
Run Time: 0.004363
Run Time: 0.000974
Params: 0, ڨ, ڨ, XF\Pub\Controller\Forum, List, valid, , 1714739276,
Run Time: 0.000259
Run Time: 0.001052
Params: 1714738376
Run Time: 0.000687
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 62 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714738376)
Run Time: 0.000993
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 62 | Using where |
Run Time: 0.000351
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712147276)
Run Time: 0.001505
Run Time: 0.001650
Run Time: 0.001308
Run Time: 0.000381
Run Time: 0.000253
Run Time: 0.000401
Run Time: 0.000268
Run Time: 0.000398
Run Time: 0.000502
Run Time: 0.001854
Run Time: 0.000376
Run Time: 0.002531
bytes_sent | 23314 |
bytes_received | 939637 |
packets_sent | 286 |
packets_received | 3429 |
protocol_overhead_in | 13716 |
bytes_received_change_user_packet | 714932 |
packets_sent_command | 142 |
packets_received_change_user | 467 |
result_set_queries | 46 |
ps_buffered_sets | 46 |
proto_binary_fetched_bit | 2911 |
proto_binary_fetched_json | 4420 |
proto_binary_fetched_blob | 1743 |
com_stmt_prepare | 47 |
com_stmt_execute | 47 |
com_stmt_close | 46 |
bytes_received_real_data_ps | 702908 |
