Run Time: 0.001467
Run Time: 0.000286
Run Time: 0.000300
Run Time: 0.000893
Run Time: 0.000342
Run Time: 0.002764
Run Time: 0.000589
Params: 0, I, I, XF\Pub\Controller\Forum, List, valid, , 1714381587,
Run Time: 0.000955
Params: 1714380687
Run Time: 0.000541
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 50 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714380687)
Run Time: 0.000655
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 50 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711789587)
Run Time: 0.001837
Run Time: 0.001165
Run Time: 0.001066
Run Time: 0.000347
Run Time: 0.000228
Run Time: 0.000246
Run Time: 0.000359
Run Time: 0.000424
Run Time: 0.001623
Run Time: 0.002357
bytes_received | 941610 |
bytes_received_change_user_packet | 714493 |
proto_binary_fetched_bit | 2900 |
bytes_received_real_data_ps | 702456 |
