Run Time: 0.001280
Run Time: 0.000259
Run Time: 0.000735
Run Time: 0.000304
Run Time: 0.002631
Run Time: 0.000597
Params: 0, ܚ), ܚ), XF\Pub\Controller\Forum, List, valid, , 1714759868,
Run Time: 0.000143
Run Time: 0.000788
Params: 1714758968
Run Time: 0.000504
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 114 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714758968)
Run Time: 0.000614
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 114 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712167868)
Run Time: 0.002338
Run Time: 0.002097
Run Time: 0.001191
Run Time: 0.000400
Run Time: 0.000263
Run Time: 0.000274
Run Time: 0.000300
Run Time: 0.000383
Run Time: 0.001658
Run Time: 0.000223
Run Time: 0.000226
Run Time: 0.002145
