Run Time: 0.001223
Run Time: 0.000353
Run Time: 0.000967
Run Time: 0.000420
Run Time: 0.002810
Run Time: 0.000704
;=w,
;=w, XF\Pub\Controller\Forum, List, valid, , 1714215189,
Run Time: 0.001200
Params: 1714214289
Run Time: 0.000491
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 76 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714214289)
Run Time: 0.000687
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 76 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711623189)
Run Time: 0.001972
Run Time: 0.001340
Run Time: 0.001124
Run Time: 0.000418
Run Time: 0.000267
Run Time: 0.000298
Run Time: 0.000239
Run Time: 0.000320
Run Time: 0.000384
Run Time: 0.002156
Run Time: 0.000308
Run Time: 0.000233
Run Time: 0.002186
bytes_received | 941620 |
bytes_received_change_user_packet | 714503 |
proto_binary_fetched_bit | 2900 |
bytes_received_real_data_ps | 702466 |
