Run Time: 0.001240
Run Time: 0.001083
Run Time: 0.000306
Run Time: 0.003552
Run Time: 0.000717
Params: 0, ▯, ▯, XF\Pub\Controller\Forum, List, valid, , 1714766632,
Run Time: 0.000870
Params: 1714765732
Run Time: 0.000489
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 154 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714765732)
Run Time: 0.000820
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 154 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712174632)
Run Time: 0.001340
Run Time: 0.001090
Run Time: 0.000870
Run Time: 0.000243
Run Time: 0.000314
Run Time: 0.000274
Run Time: 0.000425
Run Time: 0.001647
Run Time: 0.000255
Run Time: 0.002804
