Run Time: 0.001179
Run Time: 0.000959
Run Time: 0.000287
Run Time: 0.002638
Run Time: 0.000531
Params: 0, ݍ,, ݍ,, XF\Pub\Controller\Forum, List, valid, , 1714761953,
Run Time: 0.000120
Run Time: 0.000633
Params: 1714761053
Run Time: 0.000422
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 114 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714761053)
Run Time: 0.000527
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 114 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712169953)
Run Time: 0.001274
Run Time: 0.001006
Run Time: 0.000831
Run Time: 0.000205
Run Time: 0.000227
Run Time: 0.000240
Run Time: 0.000246
Run Time: 0.001519
Run Time: 0.002232
