Run Time: 0.001206
Run Time: 0.000726
Run Time: 0.000299
Run Time: 0.002271
Run Time: 0.000545
Params: 0, ui, ui, XF\Pub\Controller\Forum, List, valid, , 1714763497,
Run Time: 0.000692
Params: 1714762597
Run Time: 0.000571
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 111 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714762597)
Run Time: 0.000609
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 111 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712171497)
Run Time: 0.001576
Run Time: 0.001073
Run Time: 0.000899
Run Time: 0.000286
Run Time: 0.000349
Run Time: 0.001650
Run Time: 0.000159
Run Time: 0.002090
