Run Time: 0.001425
Run Time: 0.000267
Run Time: 0.000280
Run Time: 0.000941
Run Time: 0.000427
Run Time: 0.004515
Run Time: 0.001066
Params: 0, d", d", XF\Pub\Controller\Forum, List, valid, , 1715029980,
Run Time: 0.000205
Run Time: 0.001045
Params: 1715029080
Run Time: 0.000731
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 162 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715029080)
Run Time: 0.000866
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 162 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712437980)
Run Time: 0.001955
Run Time: 0.001572
Run Time: 0.000942
Run Time: 0.000403
Run Time: 0.000427
Run Time: 0.000396
Run Time: 0.000255
Run Time: 0.000388
Run Time: 0.000377
Run Time: 0.001954
Run Time: 0.000257
Run Time: 0.002664
