Run Time: 0.001274
Run Time: 0.000730
Run Time: 0.000308
Run Time: 0.002750
Run Time: 0.000549
Params: 0, vd0, vd0, XF\Pub\Controller\Forum, List, valid, , 1715218892,
Run Time: 0.000770
Params: 1715217992
Run Time: 0.000449
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 81 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715217992)
Run Time: 0.000602
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 81 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712626892)
Run Time: 0.001462
Run Time: 0.001410
Run Time: 0.001117
Run Time: 0.000227
Run Time: 0.000222
Run Time: 0.000445
Run Time: 0.001651
Run Time: 0.002137
