Run Time: 0.001738
Run Time: 0.000317
Run Time: 0.000387
Run Time: 0.001130
Run Time: 0.000585
Run Time: 0.002907
Run Time: 0.001005
Params: 0, hm, hm, XF\Pub\Controller\Forum, List, valid, , 1714385641,
Run Time: 0.001089
Params: 1714384741
Run Time: 0.000409
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 30 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714384741)
Run Time: 0.000703
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 30 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711793641)
Run Time: 0.001452
Run Time: 0.001604
Run Time: 0.001261
Run Time: 0.000353
Run Time: 0.000251
Run Time: 0.000346
Run Time: 0.000353
Run Time: 0.000324
Run Time: 0.000363
Run Time: 0.001552
Run Time: 0.000248
Run Time: 0.002309
bytes_received | 941537 |
bytes_received_change_user_packet | 714420 |
bytes_received_real_data_ps | 702403 |
