Run Time: 0.001373
Run Time: 0.000794
Run Time: 0.000297
Run Time: 0.002366
Run Time: 0.000542
Params: 0, )j, )j, XF\Pub\Controller\Forum, List, valid, , 1714761062,
Run Time: 0.000142
Run Time: 0.000599
Params: 1714760162
Run Time: 0.000458
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 120 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714760162)
Run Time: 0.000553
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 120 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712169062)
Run Time: 0.001359
Run Time: 0.000986
Run Time: 0.000769
Run Time: 0.000238
Run Time: 0.000847
Run Time: 0.000299
Run Time: 0.001311
Run Time: 0.000248
Run Time: 0.001730
