Run Time: 0.001151
Run Time: 0.000772
Run Time: 0.000338
Run Time: 0.002444
Run Time: 0.000523
Params: 0, t>-, t>-, XF\Pub\Controller\Forum, List, valid, , 1714960013,
Run Time: 0.000722
Params: 1714959113
Run Time: 0.000449
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 120 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714959113)
Run Time: 0.000565
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 120 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712368013)
Run Time: 0.001236
Run Time: 0.001081
Run Time: 0.000803
Run Time: 0.000241
Run Time: 0.000333
Run Time: 0.001336
Run Time: 0.002172
