Run Time: 0.001061
Run Time: 0.000247
Run Time: 0.000265
Run Time: 0.000786
Run Time: 0.002462
Run Time: 0.000688
Params: 0, w}, w}, XF\Pub\Controller\Forum, List, valid, , 1714840545,
Run Time: 0.000149
Run Time: 0.000769
Params: 1714839645
Run Time: 0.000487
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 84 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714839645)
Run Time: 0.000641
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 84 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712248545)
Run Time: 0.001282
Run Time: 0.001033
Run Time: 0.000771
Run Time: 0.000244
Run Time: 0.000313
Run Time: 0.001406
Run Time: 0.002060
bytes_received | 941856 |
bytes_received_change_user_packet | 714739 |
bytes_received_real_data_ps | 702704 |
