Run Time: 0.001450
Run Time: 0.000262
Run Time: 0.000252
Run Time: 0.000897
Run Time: 0.000326
Run Time: 0.003205
Run Time: 0.000764
Params: 0, L , L , XF\Pub\Controller\Forum, List, valid, , 1714380554,
Run Time: 0.001001
Params: 1714379654
Run Time: 0.000403
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 107 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714379654)
Run Time: 0.000676
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 107 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711788554)
Run Time: 0.001766
Run Time: 0.001437
Run Time: 0.001137
Run Time: 0.000435
Run Time: 0.000396
Run Time: 0.000345
Run Time: 0.000360
Run Time: 0.000410
Run Time: 0.002075
Run Time: 0.000292
Run Time: 0.000254
Run Time: 0.002921
bytes_received | 941610 |
bytes_received_change_user_packet | 714493 |
proto_binary_fetched_bit | 2900 |
bytes_received_real_data_ps | 702456 |
