Run Time: 0.001296
Run Time: 0.000786
Run Time: 0.000299
Run Time: 0.002613
Run Time: 0.000544
Params: 0, ],, ],, XF\Pub\Controller\Forum, List, valid, , 1714494187,
Run Time: 0.000142
Run Time: 0.000693
Params: 1714493287
Run Time: 0.000359
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 32 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714493287)
Run Time: 0.000641
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 32 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711902187)
Run Time: 0.001661
Run Time: 0.001169
Run Time: 0.000918
Run Time: 0.000226
Run Time: 0.000381
Run Time: 0.001738
Run Time: 0.002574
bytes_received | 941880 |
bytes_received_change_user_packet | 714763 |
proto_binary_fetched_bit | 2910 |
bytes_received_real_data_ps | 702736 |
