Run Time: 0.002066
Run Time: 0.000384
Run Time: 0.000401
Run Time: 0.000951
Run Time: 0.000542
Run Time: 0.002747
Run Time: 0.000691
Params: 0, ځd, ځd, XF\Pub\Controller\Forum, List, valid, , 1714968440,
Run Time: 0.000895
Params: 1714967540
Run Time: 0.000664
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 147 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714967540)
Run Time: 0.000683
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 147 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712376440)
Run Time: 0.001376
Run Time: 0.001057
Run Time: 0.001076
Run Time: 0.000264
Run Time: 0.000258
Run Time: 0.000241
Run Time: 0.000185
Run Time: 0.000282
Run Time: 0.000394
Run Time: 0.001492
Run Time: 0.000208
Run Time: 0.002246
