Run Time: 0.001493
Run Time: 0.000334
Run Time: 0.002798
Run Time: 0.000565
Run Time: 0.002745
Run Time: 0.000911
;=w,
;=w, XF\Pub\Controller\Forum, List, valid, , 1714338183,
Run Time: 0.001286
Params: 1714337283
Run Time: 0.000467
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 67 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714337283)
Run Time: 0.000683
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 67 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711746183)
Run Time: 0.002536
Run Time: 0.001269
Run Time: 0.001270
Run Time: 0.000355
Run Time: 0.000305
Run Time: 0.000434
Run Time: 0.000404
Run Time: 0.000205
Run Time: 0.000372
Run Time: 0.000382
Run Time: 0.001527
Run Time: 0.000333
Run Time: 0.002186
bytes_received | 941537 |
bytes_received_change_user_packet | 714420 |
bytes_received_real_data_ps | 702403 |
