Run Time: 0.001236
Run Time: 0.000731
Run Time: 0.000297
Run Time: 0.002317
Run Time: 0.000523
Params: 0, w, w, XF\Pub\Controller\Forum, List, valid, , 1715221341,
Run Time: 0.000128
Run Time: 0.000596
Params: 1715220441
Run Time: 0.000368
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 81 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715220441)
Run Time: 0.000485
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 81 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712629341)
Run Time: 0.001308
Run Time: 0.001391
Run Time: 0.000766
Run Time: 0.000210
Run Time: 0.000277
Run Time: 0.001148
Run Time: 0.000152
Run Time: 0.001723
