Run Time: 0.001307
Run Time: 0.000310
Run Time: 0.001110
Run Time: 0.000408
Run Time: 0.002818
Run Time: 0.000768
;d*,
;d*, XF\Pub\Controller\Forum, List, valid, , 1714912275,
Run Time: 0.000866
Params: 1714911375
Run Time: 0.000454
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 134 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714911375)
Run Time: 0.000613
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 134 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712320275)
Run Time: 0.002612
Run Time: 0.001868
Run Time: 0.001343
Run Time: 0.000457
Run Time: 0.000246
Run Time: 0.000621
Run Time: 0.000431
Run Time: 0.000352
Run Time: 0.000421
Run Time: 0.001872
Run Time: 0.000365
Run Time: 0.000312
Run Time: 0.002652
