Run Time: 0.001258
Run Time: 0.000270
Run Time: 0.000777
Run Time: 0.000335
Run Time: 0.002647
Run Time: 0.000683
Params: 0, ک2, ک2, XF\Pub\Controller\Forum, List, valid, , 1714484123,
Run Time: 0.000118
Run Time: 0.000818
Params: 1714483223
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 31 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714483223)
Run Time: 0.000578
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 31 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711892123)
Run Time: 0.001427
Run Time: 0.001037
Run Time: 0.000870
Run Time: 0.000392
Run Time: 0.000333
Run Time: 0.000269
Run Time: 0.000321
Run Time: 0.000481
Run Time: 0.001441
Run Time: 0.002208
bytes_received | 941807 |
bytes_received_change_user_packet | 714690 |
bytes_received_real_data_ps | 702683 |
