Run Time: 0.001206
Run Time: 0.000189
Run Time: 0.000742
Run Time: 0.000317
Run Time: 0.002429
Run Time: 0.000516
Params: 0, 4~J, 4~J, XF\Pub\Controller\Forum, List, valid, , 1714348500,
Run Time: 0.000123
Run Time: 0.000647
Params: 1714347600
Run Time: 0.000269
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 64 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714347600)
Run Time: 0.000498
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 64 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711756500)
Run Time: 0.001237
Run Time: 0.001006
Run Time: 0.000784
Run Time: 0.000259
Run Time: 0.001324
Run Time: 0.000159
Run Time: 0.001876
bytes_received | 941537 |
bytes_received_change_user_packet | 714420 |
bytes_received_real_data_ps | 702403 |
