Run Time: 0.001206
Run Time: 0.001117
Run Time: 0.000337
Run Time: 0.002633
Run Time: 0.000567
Params: 0, , , XF\Pub\Controller\Forum, List, valid, , 1714821316,
Run Time: 0.000126
Run Time: 0.000607
Params: 1714820416
Run Time: 0.000420
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 130 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714820416)
Run Time: 0.000603
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 130 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712229316)
Run Time: 0.001265
Run Time: 0.001150
Run Time: 0.000928
Run Time: 0.000255
Run Time: 0.000226
Run Time: 0.000280
Run Time: 0.001415
Run Time: 0.001889
bytes_received | 942102 |
bytes_received_change_user_packet | 714985 |
proto_binary_fetched_bit | 2920 |
bytes_received_real_data_ps | 702946 |
