Run Time: 0.001182
Run Time: 0.000252
Run Time: 0.000733
Run Time: 0.000342
Run Time: 0.002419
Run Time: 0.000649
Params: 0, ߠ=, ߠ=, XF\Pub\Controller\Forum, List, valid, , 1714887254,
Run Time: 0.001125
Params: 1714886354
Run Time: 0.000584
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 123 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714886354)
Run Time: 0.000692
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 123 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712295254)
Run Time: 0.001443
Run Time: 0.001011
Run Time: 0.000935
Run Time: 0.000244
Run Time: 0.000209
Run Time: 0.000274
Run Time: 0.000350
Run Time: 0.001470
Run Time: 0.000230
Run Time: 0.000157
Run Time: 0.002097
