Run Time: 0.001273
Run Time: 0.000269
Run Time: 0.000347
Run Time: 0.000941
Run Time: 0.000500
Run Time: 0.002927
Run Time: 0.000836
Params: 0, $, $, XF\Pub\Controller\Forum, List, valid, , 1714980091,
Run Time: 0.001028
Params: 1714979191
Run Time: 0.000580
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 145 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714979191)
Run Time: 0.001130
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 145 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712388091)
Run Time: 0.001934
Run Time: 0.001702
Run Time: 0.001137
Run Time: 0.000420
Run Time: 0.000309
Run Time: 0.000273
Run Time: 0.000318
Run Time: 0.000357
Run Time: 0.001771
Run Time: 0.002642
